Calculate volume of tetrahedral mesh regions
I have a tetrahedral mesh with different regions defined by common scalars. I’m trying to figure out how to use the ‘Cell Size’ filter to calculate the volume of each region, but right now I can only calculate the volume of each tetrahedral element.
I can calculate the volume of a region using the Threshold filter, and then use the Cell Size filter with ‘calculate sum’ selected to get the volume of that region, but there are a lot of regions so I can’t go through each one-by-one.
Would appreciate any help!
Thanks!
You can do this with the Programmable Filter and a fairly short script. Assume the name of your scalars that label the regions is called ‘RegionId’, then your script would look like:
# Find unique region IDs
regionArray = inputs[0].CellData['RegionId']
regions = unique(regionArray)
v = volume(inputs[0])
for regionValue in regions:
  regionVolume = sum(v[regionArray == regionValue])
  print(regionValue, regionVolume)
This will print the volume of each region value and region.
Dear Cory,
How to implement this snippet into the pvpython script?
Since unique and volume functions are undefined:
NameError: name 'unique' is not defined.
This piece of code works perfectly in python Programmable filter, but not in pvpython:(
Best regards,
Evgenii
from paraview.vtk.util import numpy_support # provides unique()
from vtkmodules.numpy_interface.algorithms import * # provides volume()
Thank you, Cory!
regionArray = connectivity2.CellData['RegionId']
regions = np.unique(regionArray) # I don't understand how to use numpy_support:(
v = volume(regionArray)
a=[]
    a.append((regionValue,regionVolume))
I have a strange error:
File “lambda2_final.py”, line 655, in
File “/Applications/ParaView-5.8.0.app/Contents/Python/vtkmodules/numpy_interface/algorithms.py”, line 140, in new_dsfunc2
return dsfunc(ds)
File “/Applications/ParaView-5.8.0.app/Contents/Python/vtkmodules/numpy_interface/internal_algorithms.py”, line 501, in volume
ds.CopyStructure(dataset.VTKObject)
AttributeError: ‘paraview.modules.vtkRemotingCore.vtkPVArrayInforma’ object has no attribute ‘CopyStructure’
Thererefore, I changed and renamed module algs
import vtk.numpy_interface.algorithms as algs
I have the following error
v = algs.volume(regionArray)
return dsfunc(ds)
