pvpython will always be a client from the point of view of ParaView and therefore, pvpython can connect to a pvserver if you want. You can see how a registered protocol in visualizer is allowing you to connect to a remote pvserver using some command line argument.
But if your goal is to run pvw-lite.py in parallel, you just need to use pvbatch with mpi instead.
