So I have just installed ParaView, and decided to follow the tutorial Introduction to Paraview, on the official documentation for ParaView. Everything works fine, until I open pvpython 5.9.0, and run the following:
from paraview.simple import *
Sphere()
Show()
Render()
The display just crashes with no bug reports, and I have no idea why. It seems to work fine when I’m working using the User Interface, but only crashes when I’m using the python shell.
Again, on my setup (Linux, 5.9.0-RC2), the following commands do NOT crash and do NOT stop responding. Note also that the commands below are slightly incomplete. You don’t have a handle to the sphere.
Thank you, that does work, to some extent. After pressing ‘q’, the window becomes unresponsive afterwards. The terminal still works, and the display continues working once I call Interact() again. I guess I was thrown off by the unresponsive window.
Yeh, after messing around with it, the shell works as usual, but the display goes unresponsive (On Windows 10) whenever it’s not currently in Interact() mode. I guess it could just be ignored, although it’s something that might be worth debugging eventually.
Not really “worth debugging” as we know exactly what causes this. The window is not answering any of the window manager attempt to communicate with it and this is how it was designed.
