I’m finding that the keyframes that I’m inserting using my macro method (Animation KeyTime integer error) don’t survive a save, close and reload of the pvsm file. Any ideas about how to make these animation keyframes stick?
Here’s a link to a screen cap with the issue shown.
While I see the issue in your video, I’m not able to reproduce it, here is a state file containing keyframes that loads correctly in 5.11-RC1: state.pvsm (198.1 KB)
Finally I want to mention that your macro makes so much sense ! Being able to do that in proper ParaView would be a net benefice ! You could open an issue about this if you want.
Hi @mwestphal, thanks for all your support these last two weeks!
That’s too bad the keyframes aren’t stored in state. I’ll submit an issue on the bug tracker.
In general do python traces pick up on things that happen as a result of script/macro executions? When I use my little macro during a trace I see a blank space between the camera updates, and animation time change lines.
and you were using my little macro to try to reproduce this? I find that the pvsm files retain their keyframes if I set them manually using the widget.
Oh thank you!! I agree that this would be a really important feature since many 3d programs do their keyframing this way. Sure I’ll open a feature issue about this too.
