Hello everyone,
I made a script to make a isosurface and save an image. But as you can see in the screenshot attached, my camera configuration cuts part of the domain.
What should I change to have the full domain without any part of it cut out from the image?
Thank you for your help in advance.
Argyris
I want my script to save the screenshot from the camera configuration that I have prescribed.
I think I found the problem. The Camera Position values in y and z were too small and I had "manually
" zoomed out by increasing the Camera Parallel Scale number.
The Camera Parallel Scale is the distance from the focal point to the top edge in grid dimensions?
I want a way, no matter the grid size and dimensions the image to have the same zoom, position and angle, without opening the GUI.
A way that I found is to set Camera Parallel Scale equal to a fraction of my vertical height dimension:
CameraParallelScale=1.8*y[-1] for example.
It seems to produce well fitted images no matter the dimensions of my grid but if you have a better solution I would be happy to implement.
Thank you for your time.
