hello
https://gitlab.kitware.com/paraview/paraview/blob/master/Documentation/dev/build.md
When using the site method above on Ubuntu, some plugins in Paraview do not build.
what’s the problem?
The currently used Ubuntu uses 22.04LTS.
hello
what’s the problem?
Per https://gitlab.kitware.com/paraview/paraview/blob/master/Documentation/dev/build.md#plugin-settings, you’ll need to set PARAVIEW_PLUGIN_ENABLE_<name> to ON to enable individual plugins. Check those settings first.
Not sufficient.
My custom plugin still is not build this way
