MAJED
(majed nashaat)
June 20, 2020, 12:06pm
1
Hi
Can I plot 3d surface (3d list plot) in paraview. The data entry has the form (I attached it)
10 20 30 40 50 60 70 80
1.3 3.2 4.5 5 3.2 2.2 2 1.5
… … … … … … … …data_1.txt (1.6 MB)
Thanks in Advance
Maybe there is not 3D plots in ParaView:
https://discourse.paraview.org/t/plotting-points-on-a-rectangular-grid-with-paraview/3146
Therefore, I tried to use a Programmable Source with your data, but it was a bit complicated. (state file is here: 3d_plot.pvsm (298.2 KB) )
Set the Output Data Set Type to vtkImageData under the Programmable Source Properties.
Declare the extent in Script (RequestInformation) .
from paraview import util
util.SetOutputWholeExtent(self, [0, 3000, 0, 50, 0, 0])
Load the data and assign them to the source output as a field data in Script . You need to modify “Path/To/Data/Folder”.
import numpy as np
from io import StringIO
output.SetDimensions(3001,51,1)
output.SetSpacing(1,60,1)
file_name = 'Path/To/Data/Folder/data_1.txt'
# remove \t at the end of sentence
file = open(file_name,'r')
string = file.read()
file.close()
string = string.strip('\t')
string = StringIO(string)
data = np.loadtxt(string)
print(data.shape)
output.PointData.append(data.flatten(), 'data_1')
Apply the Warp by Scalar filter .
