Can paraview can export animation while using export scene option and using glTF as output format?
I have an animated flow and I want to export it into some sort of 3d output standard.
I’m afraid saving timestep into a .gltf is not supported yet.
If you want a glTF so that you can share the animation online, I’ll point out that Sketchfab supports flipbook-style animation where you give it a model for each timestep. Using the technique I described in this post, I’ve been able to successfully export ParaView animations to Sketchfab.
