I have PV5.10.0 compiled from source, with Qt for my laptop. I cannot configure iparaview-kernel:
CMake Error at /local/apps/ParaView/5.10/lib/cmake/paraview-5.10/paraview-config.cmake:163 (list):
list sub-command REMOVE_ITEM requires two or more arguments.
CMakeLists.txt:17 (find_package)
This error is not limited to iparaview-kernel. I have the same error attempting to compile any plugin, such as for example:
would it be possible for you to try with CMake 3.21 ? I already saw this issue and this version of cmake solved it then.
Also, please ensure you are using the latest master of the iparaview-kernel as we added some fix few days ago
This error seems to appear when building any plugin against an install folder of ParaView while using CMake < 3.21 (as far as I’ve tested). Imo this is a bug in ParaView and this should be adressed. I will open an issue and try to pindown the exact CMake version that breaks compatibility.
indeed, I installed cmake via pip and got v3.22.2.
I can configure but it fails later on on:
[ 71%] Building CXX object PVQtJupyterPlugin/CMakeFiles/PVQtJupyterPlugin.dir/pqJupyterTraceReaction.cxx.o
In file included from /local/apps/ParaView/5.10/include/paraview-5.10/pqPythonScriptEditor.h:38,
from /home/jfavre/Projects/ParaView/iparaview-kernel/PVQtJupyterPlugin/pqJupyterTraceReaction.cxx:9:
/local/apps/ParaView/5.10/include/paraview-5.10/pqPythonEditorActions.h:36:10: fatal error: pqPythonUtils.h: No such file or directory
36 | #include “pqPythonUtils.h”
compilation terminated.
@jfavre yes sadly this plugin cannot compile against vanilla 5.10 . See the iparaview-kernel README and the Patches/ folder to have the necessary patches.
I saw the README and was confused because it said if there is a version number, that means this patch is no longer needed. I see ParaView_MR_5387.patch and ParaView_MR_5446.patch and thought these numbers were versions. Sorry about that.
I applied the patch, rebuilt, and I can now compile to the end.
I have tested jupyter notebook and it works as advertized. Thanks for the prompt help.
Indeed it can be a bit confusing, I will rename them. ParaView_MR_5446.patch should be backported to 5.10.1, but it’s still unsure for the other one. I’ll post a message here and update the name accordingly when I know more.
