I am connecting to a remote pvserver running on a Linux cluster node via an SSH tunnel. I have built paraview 5.9.1 from source on the cluster node.
I can successfully create the tunnel, start pvserver on the node, and connect from a Windows 10 Paraview 5.9.1 client, but I cannot connect from a macOS 11.4 (Big Sur) Paraview 5.9.1 client. When attempting to connect from macOS, I get the error:
ERROR: In /opt/glr/paraview/paraview-ci/build/superbuild/paraview/src/VTK/Parallel/Core/vtkSocketCommunicator.cxx, line 781
vtkSocketCommunicator (0x600003c3aeb0): Could not receive tag. 1010580540
ERROR: In /opt/glr/paraview/paraview-ci/build/superbuild/paraview/src/VTK/Parallel/Core/vtkSocketCommunicator.cxx, line 535
vtkSocketCommunicator (0x600003c3aeb0): Endian handshake failed.
ERROR: In /opt/glr/paraview/paraview-ci/build/superbuild/paraview/src/Remoting/Core/vtkTCPNetworkAccessManager.cxx, line 333
vtkTCPNetworkAccessManager (0x600001b44900):
Connection failed during handshake. vtkSocketCommunicator::GetVersion()
returns different values on the two connecting processes
(Current value: 100).
What causes this error code? Is there a way to workaround this issue?
Yes, I am certain they are the same version of ParaView. I built the server ParaView with the options: -DCMAKE_BUILD_TYPE=RelWithDebInfo -DPARAVIEW_USE_MPI=ON -DPARAVIEW_USE_QT=OFF -DCMAKE_INSTALL_PREFIX=/avatar/bwibking/paraview_install -DCMAKE_CXX_COMPILER=g++ -DCMAKE_C_COMPILER=gcc -DPARAVIEW_USE_PYTHON=ON -DVTK_OPENGL_HAS_EGL=ON
I installed the pre-compiled binary from ParaView-5.9.1-osmesa-MPI-Linux-Python3.8-64bit.tar.gz on my cluster and tried to connect, but I get the same error:
vtkSocketCommunicator (0x6000035c2130): Could not receive tag. 1010580540
vtkSocketCommunicator (0x6000035c2130): Endian handshake failed.
vtkTCPNetworkAccessManager (0x6000012f7b80):
Arg, this was very annoying. It works only if I set up the tunnel using the fully-qualified domain name of the cluster node.
It would be nice if ParaView gave a more sensible error message in this case. I don’t understand why the tunnel needs to be set up this way, or why pvserver cares about the FQDN, though.
That’s good to know this is being tracked in the case of an actual version mismatch. Do you know why setting up a tunnel using a different hostname than the one printed to stdout by pvserver causes a version mismatch error?
