I have an NVIDIA Corporation GK104GL [Quadro K4200] in my cluster, but I’m experiencing very slow GPU rendering. I also receive the message: “Display is not accessible on the server side. Remote rendering will be disabled.” This issue is causing significant lag, and rendering tasks often lead to crashes. I would greatly appreciate any assistance in resolving this so that I can fully utilize the cluster’s capabilities. Additionally, the Kitware website link seems to be broken (404 error).
Do your server have a GPU ?
Does your server run a graphical environnement ?
Which ParaView version are you using server side ?
mslab@mslab-Precision-Tower-7910:~$ lshw -class display
WARNING: you should run this program as super-user.
*-display
description: VGA compatible controller
product: GK104GL [Quadro K4200]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:04:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: vga_controller bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: irq:90 memory:e8000000-e8ffffff memory:b0000000-bfffffff memory:c0000000-c1ffffff ioport:4000(size=128) memory:e9000000-e907ffff
WARNING: output may be incomplete or inaccurate, you should run this program as super-user.
This I have typed for finding display but I think this is not available to gpu or something due to not updating the driver
And I have tried using both osmessa and egl for the same
For example is a XOrg server running ?
Yes xorg was running
top - 19:23:06 up 6 days, 9:08, 1 user, load average: 16.12, 16.10, 16.09
Tasks: 513 total, 2 running, 309 sleeping, 0 stopped, 1 zombie
%Cpu(s): 0.3 us, 2.6 sy, 0.0 ni, 97.1 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
KiB Mem : 13193588+total, 94888752 free, 4146124 used, 32901012 buff/cache
KiB Swap: 2097148 total, 2004720 free, 92428 used. 12672622+avail Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 1514 root 20 0 6572132 29904 25340 R 100.0 0.0 3393:13 Xorg
are you able to run glxinfo ?
No Sir
127|:/data/user/0/com.server.auditor.ssh.client/files/private $ glxinfo
: glxinfo: inaccessible or not found
You need to install glxinfo and make sure it works, eg using DISPLAY=:0 and xhost+. Only then will pvserver be able to work.
Alternatively, you can use the EGL release.
