I am attempting to get the basic catalyst implementation in The Catalyst User’s Guide v2.0 working on the simulation framework I am working on, but I have run into issues.
I took my CMakeLists.txt from the Catalyst User’s Guide. I have copied it below.CMakeLists.txt (507 Bytes)
I have also added the CMakeCache.txt generated from the above file.
CMakeCache.txt (40.2 KB)
To preface, my machine is running Ubuntu 18.04 and I am using Paraview 5.8 which I retrieved and built from
https://www.paraview.org/Wiki/ParaView:Build_And_Install
After running cmake .. I get the following error:
CMake Warning (dev) in CMakeLists.txt:I took the CMakeLists.txt from
No project() command is present. The top-level CMakeLists.txt file must
contain a literal, direct call to the project() command. Add a line of
code such asproject(ProjectName)near the top of the file, but after cmake_minimum_required().
CMake is pretending there is a “project(Project)” command on the first
line.
This warning is for project developers. Use -Wno-dev to suppress it.CMake Warning (dev) at /home/student/Documents/cmake-3.17.3-Linux-x86_64/share/cmake-3.17/Modules/FindPackageHandleStandardArgs.cmake:272 (message):
The package name passed tofind_package_handle_standard_args(MPI_C) does
not match the name of the calling package (MPI). This can lead to problems
in calling code that expectsfind_packageresult variables (e.g.,
_FOUND) to follow a certain pattern.
/home/student/Documents/Paraview/ParaviewDr.Bauer/paraview/VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/CMake/FindMPI.cmake:1695 (find_package_handle_standard_args)
/home/student/Documents/Paraview/ParaviewDr.Bauer/paraview_build/lib/cmake/paraview-4.3/vtk/VTK-vtk-module-find-packages.cmake:250 (find_package)
/home/student/Documents/Paraview/ParaviewDr.Bauer/paraview_build/lib/cmake/paraview-4.3/vtk/vtk-config.cmake:138 (include)
/home/student/Documents/Paraview/Paraview5.8/paraview_build/lib/cmake/paraview-5.8/paraview-config.cmake:53 (find_package)
/home/student/Documents/Paraview/Paraview5.8/paraview_build/paraview-config.cmake:1 (include)
CMakeLists.txt:5 (find_package)
This warning is for project developers. Use -Wno-dev to suppress it.CMake Warning (dev) at /home/student/Documents/Paraview/Paraview5.8/paraview_build/lib/cmake/paraview-5.8/ParaView-vtk-module-find-packages.cmake:14 (if):
Policy CMP0057 is not set: Support new IN_LIST if() operator. Run “cmake
–help-policy CMP0057” for policy details. Use the cmake_policy command to
set the policy and suppress this warning.IN_LIST will be interpreted as an operator when the policy is set to NEW.
Since the policy is not set the OLD behavior will be used.
/home/student/Documents/Paraview/Paraview5.8/paraview_build/lib/cmake/paraview-5.8/paraview-config.cmake:78 (include)
This warning is for project developers. Use -Wno-dev to suppress it.CMake Error at /home/student/Documents/Paraview/Paraview5.8/paraview_build/lib/cmake/paraview-5.8/ParaView-vtk-module-find-packages.cmake:14 (if):
if given arguments:"_vtk_module_component" "IN_LIST" "_vtk_module_find_package_components_checked"Unknown arguments specified
CMakeLists.txt:5 (find_package)CMake Error at CMakeLists.txt:5 (find_package):
Found package configuration file:/home/student/Documents/Paraview/Paraview5.8/paraview_build/paraview-config.cmakebut it set ParaView_FOUND to FALSE so package “ParaView” is considered to
be NOT FOUND. Reason given by package:The following imported targets are referenced, but are missing:
VTK::RenderingRayTracing VTK::IOIoss VTK::IOCONVERGECFD
** VTK::AcceleratorsVTKmFilters VTK::AcceleratorsVTKmCore**– Configuring incomplete, errors occurred!
See also “/home/student/Documents/Athena/code/Athena-RFX.4.3.0_PS_CVersion.Catalyst.temp/src/CMakeFiles/CMakeOutput.log”.
See also “/home/student/Documents/Athena/code/Athena-RFX.4.3.0_PS_CVersion.Catalyst.temp/src/CMakeFiles/CMakeError.log”.
I believe this issue is caused by am improper build of Paraview so I will also add my Paraview’s CMakeCache file.
CMakeCache.txt (235.0 KB)
If you have issues with the formatting of this post please let me know as I am new to this.
Thank you.
