Cannot read VTU file with `The data array in the element may be too short.` message
I have a following python script to take the time-average of XDMF file, which works completely fine with my MacBook Pro.
#### import the simple module from the paraview
from paraview.simple import *
from pathlib import Path
import argparse
#### disable automatic camera reset on 'Show'
def parse_command_line_args() -> argparse.Namespace:
    parser = argparse.ArgumentParser()
    parser.add_argument("--input_path", type=str, required=True)
    return parser.parse_args()
def compute_time_average(input_path):
    print(" -- Reading file: ", input_path)
    xdmf_file = XDMFReader(FileNames=[input_path])
    print(" -- File read successfully")
    # create a new 'Temporal Statistics'
    print(" -- Computing time average")
    temporalStatistics1 = TemporalStatistics(registrationName='TemporalStatistics1', Input=xdmf_file)
    # Properties modified on temporalStatistics1
    temporalStatistics1.ComputeMinimum = 0
    temporalStatistics1.ComputeMaximum = 0
    temporalStatistics1.ComputeStandardDeviation = 0
    output_path = input_path.replace('.xdmf', '_time_average.vtu')
    # save data
    SaveData(output_path, proxy=temporalStatistics1, DataMode='Ascii')
    print(" -- Time average computed successfully and saved to: ", output_path)
    # delete objects
    del xdmf_file
    del temporalStatistics1
def main():
    args = parse_command_line_args()
    compute_time_average(args.input_path)
if __name__ == "__main__":
    main()
However, when I use this on the cluster, some files cannot be read with the following message.
A few files were fine, but most of the files throw the same error message. I opened up .vtu file and checked the number of components, but cannot really find any problem.
ERROR: In /opt/glr/paraview/paraview-ci/build/superbuild/paraview/src/VTK/IO/XML/vtkXMLDataReader.cxx, line 410
vtkXMLUnstructuredGridReader (0x167254170): Cannot read point data array "displacement_25_to_1000_amplitude_average" from PointData in piece 0.  The data array in the element may be too short.
In this google drive, you can find working and not-working VTU files.
https://drive.google.com/drive/folders/1-UU466lmmwOG1ep98IoN6Jcr0Edz8veR?usp=sharing
Opens fine with ParaView 5.12.0 Linux binary release:
Which version of paraview are you using on your cluster ?
On the cluster, I first tried ParaView-5.12.0-egl-MPI-Linux-Python3.10-x86_6 but got an error
malloc_consolidate(): invalid chunk size
error: exception occurred: Subprocess aborted
So, I switched to ParaView-5.10.1-egl-MPI-Linux-Python3.9-x86_64, which did not give an error but the file was corrupted.
I’m using the cluster to generate .vtu file and read it on my local Mac computer after downloading. I tried Paraview 5.10, 5.11, 5.12 on my Mac but none of them was able to read this vtu file.
Update: I managed to run with ParaView-5.12.0-egl-MPI-Linux-Python3.10-x86_6 but the problem still happens when I tried to read on my Mac.
I found a solution to this problem. Opening the .vtu file, I noticed that
<DataArray type="Float32" Name="displacement_25_to_1000_amplitude_average" NumberOfComponents="3" format="ascii" RangeMin="0" RangeMax="3.0032659276248584e-7">
type was Float32. Changing it to Float64 manually solved the problem.
@mwestphal Could you please let me know how to specify the type when saving data?
Using a Calculator should let you do that but since is not really a fix imo.
Thanks for the answer. Yes, that’s not really a fix but will do the job for me. Not sure if this is a bug that needs to be reported.
Have you considered writing out the data in binary format instead of ASCII format? I suspect there is a parse error somewhere when reading in the text representation of numbers.
Thank you so much! It solved my problem!:slight_smile:
Hei, I just came across this issue and i wondered if there is any other solution than writing binary? I am using VTKFortran to write to a vtu file, when reading it with ParaView I get the same error as Kei:
ERROR: In vtkXMLDataReader.cxx, line 399vtkXMLUnstructuredGridReader (000001DB7D44B680): Cannot read point data array “Displacement” from PointData in piece 0. The data array in the element may be too short.
I tried changing type=“Float32” to type=“Float64” manually, but that did not work for me. I can open the same file using GLView Inova without any error.
I am using version 6.0.1
Client Information:
Version: 6.0.1
VTK Version: 9.5.2
Qt Version: 6.9.0
vtkIdType size: 64bits
Embedded Python: On
Python Library Path: C:\Program Files\ParaView 6.0.1\bin\Lib
Python Library Version: 3.12.7 (tags/v3.12.7:0b05ead, Oct 1 2024, 03:06:41) [MSC v.1941 64 bit (AMD64)]
Python Numpy Support: On
Python Numpy Path: C:\Program Files\ParaView 6.0.1\bin\lib\site-packages\numpy
Python Numpy Version: 1.26.4
Python Matplotlib Support: On
Python Matplotlib Path: C:\Program Files\ParaView 6.0.1\bin\lib\site-packages\matplotlib
Python Matplotlib Version: 3.7.2
Python Testing: Off
MPI Enabled: Off
ParaView Build ID: superbuild 8c0f929966f005396802f3b2957c734a6c68b3c1 (!1292)
Disable Registry: Off
Test Directory:
Data Directory:
SMP Backend: TBB
SMP Max Number of Threads: 28
OpenGL Vendor: NVIDIA Corporation
OpenGL Version: 3.2.0 NVIDIA 573.40
OpenGL Renderer: NVIDIA RTX 2000 Ada Generation Laptop GPU/PCIe/SSE2
Connection Information:
Remote Connection: No
I found out that the issue in my case was actually not the vector DataArray (“Displacement”) , but a previous scalar data array that appeared twice with the same name (“Temperature”). The error message was a bit misleading, renaming the second appearance of the scalar DataArray (“Temperature”→“TemperatureM”) fixed the issue for me.
