arturp97
(Artur)
January 27, 2022, 8:49am
1
When i open the file .e from DICe 2D appears this error message below. What should i do?
-- ERROR: In C:\glr\builds\paraview\paraview-ci\build\superbuild\paraview\src\VTK\IO\IOSS\vtkIOSSReader.cxx, line 687
vtkIOSSReader (000002D4ABD85820): No filename specified.
ERROR: In C:\glr\builds\paraview\paraview-ci\build\superbuild\paraview\src\VTK\Common\ExecutionModel\vtkExecutive.cxx, line 753
vtkPVCompositeDataPipeline (000002D49FFF4E40): Algorithm vtkIOSSReader(000002D4ABD85820) returned failure for request: vtkInformation (000002D4A198B8F0)
Debug: Off
Modified Time: 462280
Reference Count: 1
Registered Events: (none)
Request: REQUEST_INFORMATION
FORWARD_DIRECTION: 0
ALGORITHM_AFTER_FORWARD: 1
pavel
(Pavel Novikov)
January 27, 2022, 9:00am
4
It is opened in PV 5.9.1:
without error messages.
arturp97
(Artur)
January 27, 2022, 9:05am
5
i’m using the version 5.10. Where can i find 5.9.1 version?
pavel
(Pavel Novikov)
January 27, 2022, 9:06am
6
here https://www.paraview.org/download/
just choose 5.9 in a Version field, then find “ParaView-5.9.1-…” below
mwestphal
(Mathieu Westphal (Kitware))
7
Another issue with the IOSS reader FYI @utkarsh.ayachit
Here’s the error from paraview master. Exodus does not support global Id value 0.
( 8.283s) [paraview ] vtkIOSSReader.cxx:3115 ERR| Error reading entity block (or set) named 'block_1' from '/tmp/DICe_solution.e'; skipping. Details:
ERROR: node mapping routines detected non-positive global id 0 for local id 1 on processor 0, filename '/tmp/DICe_solution.e'.
