Can't plot custom range while using "Plot Over Line"
Dear Paraview Support,
I am trying to plot a curve where the y-axis represents the velocity magnitude, whereas the x-axis represents the x-coordinates (image attached). In the properties panel, I can see that a custom range can be specified for the bottom axis, however, it only allows for mentioning a range (i.e. a maximum & a minimum value).
My question is “can I selectively remove the data from x = -0.05 to 0.05 and plot the rest i.e. 0.76 < x < 0.05 and -0.05 < x < -0.76”?
You will need to filter your data before the plot. For instance using a Threshold filter.
Thanks for your answer. That helped. However, the Threshold filter wasn’t showing the x-coordinate values in the scalars list, so I included a calculator to pass on that array, and it worked.
