I’m using Linux Mint 19.1 on an office computer which has an NVIDIA graphics card and I’m trying to run Paraview on it. It used to work a while back, but for some reason it’s not working anymore.
I’ve first tried to install via command-line with apt install paraview. When I run Paraview installed via this method, the Paraview window opens but it stays all gray and the header says "Paraview 5.4.1 64-bit (Legacy rendering backend). (And I obviously can’t do anything because the whole window is gray.)
If I try to download and run the binaries (I’ve tried versions 5.2 to 5.6.2) they don’t open anything. I just get a message on the terminal saying Aborted.
I suspect the issue has to do with the NVIDIA drivers, but I’m really not familiar with graphics card enough to figure out what’s going on. When I follow this answer to check if NVIDIA is working, the output is that it is:
name of display: :0
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 154 (GLX)
Minor opcode of failed request: 24 (X_GLXCreateNewContext)
Value in failed request: 0x0
Serial number of failed request: 85
Current serial number in output stream: 86
As for NVS 310, seems like it’s the card model, right? Since this is an office desktop I can’t change that.
NVS310 is indeed your GPU, It juste strike me as odd.
According to wikipedia, it is a 2012 card, very old, and :
The Nvidia Quadro NVS graphics processing units (GPUs) provide business graphics solutions for manufacturers of small, medium, and enterprise-level business workstations. The Nvidia Quadro NVS desktop solutions enable multi-display graphics for businesses such as financial traders.
So, can you check this is actually your GPU model ?
In any case, your glxinfo output clearly shows the you either of driver issue (not the correct drivers installed or not up to date), or a GPU hardware issue (less likely).
