Hello –
I have installed Paraview 5.9.0 on Windows 7 Pro (64 bit). The path is –
D:\Engineering\Paraview\ParaView-5.9.0-Windows-Python3.8-msvc2017-64bit\bin\paraview.exe
When I start ParaView from an administrative cmd window I get the following –
The contents of the Output Messages window are listed below. The significant warning seems to be –
"warning: QWindowsEGLContext: ANGLE only partially supports OpenGL ES > 3.0"
(My OpenGL version is 3.1.0 - Build 9.17.10.4229)
When I try to close the Output Messages window it just reappears in the same location.
I'm running from a Lenovo X220 laptop with an integrated graphics card (Intel HD Graphics 3000; latest driver 9.17.10.4229 - 5/26/2015) with output to a HP 27yh monitor in vertical orientation. (A second vertical monitor is also attached.)
The same ParaView version on a Windows 10 laptop using the laptop's integrated display runs without problems.
Thanks for any suggestions.
Don C.
warning: In unknown, line 0
warning: QWindowsEGLContext: Failed to create context, eglError: 3005, this: 0x1c429700
warning: QWindowsEGLContext: Failed to create context, eglError: 3005, this: 0x25c54350
warning: QOpenGLWidget: Failed to create context
warning: QWindowsEGLContext: Failed to create context, eglError: 3005, this: 0x25c54580
warning: QWindowsEGLContext: Failed to create context, eglError: 3005, this: 0x25a467f0
warning: QWindowsEGLContext: Failed to create context, eglError: 3005, this: 0x25a4e3b0
warning: composeAndFlush: QOpenGLContext creation failed
warning: QWindowsEGLContext: Failed to create context, eglError: 3005, this: 0x25a4d310
warning: composeAndFlush: makeCurrent() failed
warning: QWindowsEGLContext: Failed to create context, eglError: 3005, this: 0x25a49a70
warning: QWindowsEGLContext: Failed to create context, eglError: 3005, this: 0x25a4d4f0
warning: QWindowsEGLContext: Failed to create context, eglError: 3005, this: 0x25a4d590
warning: QWindowsEGLContext: Failed to create context, eglError: 3005, this: 0x25a53940
warning: QWindowsEGLContext: Failed to create context, eglError: 3005, this: 0x25a54230
warning: QWindowsEGLContext: Failed to create context, eglError: 3005, this: 0x25a539e0
warning: QWindowsEGLContext: Failed to create context, eglError: 3005, this: 0x25a47400
warning: QWindowsEGLContext: Failed to create context, eglError: 3005, this: 0x25a47590
warning: QWindowsEGLContext: Failed to create context, eglError: 3005, this: 0x25a53620
