I am trying to connect from Jupyter to a catalyst in situ simulation, but Jupyter freezes in the moment, when the in situ side connects. ( The aim of this experiment is to show some statistics, no graphics, in Jupyter from the insitu side.)
What I did:
- Installed the iparaview kernel in Jupyter, works without problems
- Run a modified version of Examples/PythonClient/catalystLiveVisualizer.py in Jupyter
- Start ./CxxFullExample feslicescript.py as suggested in the above example
- at this moment, the _monitorServerNotifications() loop stops
I attach my modified version of Examples/PythonClient/catalystLiveVisualizer.py with the following changes:
- all Rendering related calls removed
- _monitorServerNotifications(), _updateEventCb(), _connectionCreatedEventCb() print a message
When I start the attached script in pvpython, it works as expected, shows “waiting…” repeatedly, then the outputs from the connectionCreated and updateEvent callbacks after I start the insitu side.
When I start the script in Jupyter, it shows
Accepting connection(s): myhost:22222
waiting...
waiting...
waiting...
… and the output stops when I start the insitu side.
Questions:
Do you have any idea, what interrupts _monitorServerNotifications()? I also wrote the messages to a file to be sure that not the Jupyter output capturing is the problem.
How can I start debugging this problem?
I know that the problem may be the Jupyter side. But I assume that many of the Paraview community - at least the iparaview-kernel developers - have more insight into Jupyter than most Jupyter developers know about Paraview.
Thanks, Gregor
catalystLiveVisualizer-debug.py (1.8 KB)
