The following only applies to Catalyst V2.
The https://gitlab.kitware.com/paraview/catalyst project does 2 things:
- defines the CatalystV2 API
- provides a stub implementation which is simply does nothing.
The reasoning behind providing this stub implementation is that simulation developer can compile their simulation codes linked with Catalyst without requiring a ParaView SDK build. The stub, however, as the name suggests does nothing right now (we are working making it generate binary data dumps for ease of debugging currently, so it’ll start doing that soon).
If the stub does nothing, how does one do any data analysis? The idea is that we will have different implementations of the Catalyst API that are binary compatible with the stub. A ParaView 5.9+ build, for example, provides a Catalyst API implementation, which we now refer to as ParaView-Catalyst. So look in your ParaView install directory. There will be a libcatalyst.so.2 there too. To make the example use this, simply set the environment variable LD_LIBRARY_PATH to this directory in the ParaView install and the example will load ParaView-Catalyst library instead. Now you should see the printouts as follows:
( 2.099s) [pvbatch ] v2_internals.py:152 WARN| Module 'catalyst_pipeline' missing Catalyst 'options', will use a default options object
executing (cycle=0, time=0.0)
grid:
bounds: (0.0, 69.0, 0.0, 64.9, 0.0, 55.9)
velocity-range: (0.0, 0.0)
pressure-range: (1.0, 1.0)
particles:
bounds: (1.0, 66.0, 1.0, 61.0, 4.0, 53.0)
executing (cycle=1, time=0.1)
grid:
velocity-range: (0.0, 6.490000000000001)
particles:
bounds: (0.0, 61.0, 5.0, 59.0, 2.0, 54.0)
Another tip: to debug, try setting another environment variable PARAVIEW_LOG_CATALYST_VERBOSITY=INFO and then run the example. Now you’ll see more verbose output logging internal decisions which can be handy when debugging.
env PARAVIEW_LOG_CATALYST_VERBOSITY=INFO ./bin/CxxMultiChannelInputExampleV2 ~/.../cat
alyst_pipeline.py
( 0.499s) [main thread ] ParaViewCatalyst.cxx:91 INFO| { catalyst_initialize
( 0.500s) [main thread ]vtkCatalystBlueprint.cx:195 INFO| . { catalyst: verify
( 0.500s) [main thread ]vtkCatalystBlueprint.cx:61 INFO| . . { catalyst::scripts: verify
( 0.500s) [main thread ]vtkCatalystBlueprint.cx:80 INFO| . . . script: '.../catalyst_pipeline.py'
( 0.500s) [main thread ]vtkCatalystBlueprint.cx:61 INFO| . . } 0.000 s: catalyst::scripts: verify
( 0.500s) [main thread ]vtkCatalystBlueprint.cx:195 INFO| . } 0.000 s: catalyst: verify
( 0.500s) [main thread ]vtkInSituInitialization:78 INFO| . { Initializing MPI communicator using 'comm' (0)
( 0.500s) [main thread ]vtkInSituInitialization:78 INFO| . } 0.001 s: Initializing MPI communicator using 'comm' (0)
( 0.500s) [main thread ]vtkInSituInitialization:106 INFO| . Initializing Catalyst
( 0.738s) [pvbatch ] ParaViewCatalyst.cxx:132 INFO| . Analysis script: '.../catalyst_pipeline.py'
( 0.738s) [pvbatch ] ParaViewCatalyst.cxx:91 INFO| } 0.239 s: catalyst_initialize ( 0.766s) [pvbatch ] ParaViewCatalyst.cxx:175 INFO| { catalyst_execute
( 0.766s) [pvbatch ]vtkCatalystBlueprint.cx:378 INFO| . { catalyst: verify
( 0.767s) [pvbatch ]vtkCatalystBlueprint.cx:243 INFO| . . catalyst::state: verify
( 0.767s) [pvbatch ]vtkCatalystBlueprint.cx:262 INFO| . . 'timestep' set to 0
( 0.767s) [pvbatch ]vtkCatalystBlueprint.cx:287 INFO| . . 'time' set to 0.000000
( 0.767s) [pvbatch ]vtkCatalystBlueprint.cx:353 INFO| . . { catalyst::channels: verify
( 0.767s) [pvbatch ]vtkCatalystBlueprint.cx:297 INFO| . . . { catalyst::channels::channel['grid']: verify
( 0.767s) [pvbatch ]vtkCatalystBlueprint.cx:332 INFO| . . . . { Conduit Mesh blueprint verified.
( 0.767s) [pvbatch ]vtkCatalystBlueprint.cx:332 INFO| . . . . } 0.000 s: Conduit Mesh blueprint verified.
( 0.767s) [pvbatch ]vtkCatalystBlueprint.cx:297 INFO| . . . } 0.001 s: catalyst::channels::channel['grid']: verify
( 0.767s) [pvbatch ]vtkCatalystBlueprint.cx:297 INFO| . . . { catalyst::channels::channel['particles']: verify
( 0.767s) [pvbatch ]vtkCatalystBlueprint.cx:297 INFO| . . . } 0.000 s: catalyst::channels::channel['particles']: verify
( 0.767s) [pvbatch ]vtkCatalystBlueprint.cx:353 INFO| . . } 0.001 s: catalyst::channels: verify
( 0.767s) [pvbatch ]vtkCatalystBlueprint.cx:378 INFO| . } 0.001 s: catalyst: verify
( 0.767s) [pvbatch ] ParaViewCatalyst.cxx:198 INFO| . { co-processing for timestep=0, time=0.000000
( 0.768s) [pvbatch ] ParaViewCatalyst.cxx:219 INFO| . . Conduit Mesh blueprint validation succeeded for channel (grid)
( 0.771s) [pvbatch ] ParaViewCatalyst.cxx:219 INFO| . . Conduit Mesh blueprint validation succeeded for channel (particles)
( 2.060s) [pvbatch ] detail.py:80 INFO| . . creating producer for simulation input named '%s'
( 2.064s) [pvbatch ] detail.py:80 INFO| . . creating producer for simulation input named '%s'
( 2.066s) [pvbatch ] v2_internals.py:152 WARN| . . Module 'catalyst_pipeline' missing Catalyst 'options', will use a default options object
( 2.070s) [pvbatch ] v2_internals.py:98 INFO| . . called do_catalyst_initialize <module 'catalyst_pipeline' from '/catalyst_pipeline.py'>
( 2.070s) [pvbatch ]vtkCPPythonScriptV2Help:592 INFO| . . treating as activated due to presence of custom callbacks
( 2.070s) [pvbatch ] v2_internals.py:114 INFO| . . called do_catalyst_execute <module 'catalyst_pipeline' from '.../catalyst_pipeline.py'>
( 2.071s) [pvbatch ] v2_internals.py:118 INFO| . . calling 'catalyst_pipeline.catalyst_execute'
grid:
particles:
