ParaView is not capable of applying the CellDatatoPointData filter after the AngularPeriodicFilter: it crashes with the following error:
(3653.711s) [paraview ]vtkGenericDataArray.txx:268 ERR| 27vtkAngularPeriodicDataArrayIfE (0x2ad40d37b250): GetVoidPointer is not supported by this class.
I am using the following version of ParaView:
Client Information: Version: 5.10.1 VTK Version: 9.0.20210922 Qt Version: 5.12.9 vtkIdType size: 64bits Embedded Python: On Python Library Path: /ccc/cont003/dsku/blanchet/home/user/isae/alvesrig/ParaView/5.10.1/lib/python3.9 Python Library Version: 3.9.5 (default, Mar 14 2022, 17:13:12) [GCC 7.3.1 20180303 (Red Hat 7.3.1-5)] Python Numpy Support: On Python Numpy Path: /ccc/cont003/dsku/blanchet/home/user/isae/alvesrig/ParaView/5.10.1/lib/python3.9/site-packages/numpy Python Numpy Version: 1.21.1 Python Matplotlib Support: On Python Matplotlib Path: /ccc/cont003/dsku/blanchet/home/user/isae/alvesrig/ParaView/5.10.1/lib/python3.9/site-packages/matplotlib Python Matplotlib Version: 3.2.1 Python Testing: Off MPI Enabled: On ParaView Build ID: superbuild 6dd132601dbb2a9ebdc0d31825989f5b92595b76 (!969) Disable Registry: Off Test Directory: Data Directory: SMP Backend: TBB SMP Max Number of Threads: 72 OpenGL Vendor: NVIDIA Corporation OpenGL Version: 3.2.0 NVIDIA 440.64.00 OpenGL Renderer: Tesla V100-PCIE-32GB/PCIe/SSE2 Connection Information: Remote Connection: No
It works if the filters are applied on the opposite order (i.e. first CellDatatoPointData, then AngularPeriodicFilter).
Kind regards,
