I’m trying to import an unstructured CGNS file into ParaView. If I create this file in full the mesh loads in fine and displays some wall distance data attached to the mesh correctly. However, if I create a second file with links to each of the items under Zone in the original mesh file I get the following error:
ERROR: In C:\glr\builds\paraview\paraview-ci\build\superbuild\paraview\src\VTKExtensions\CGNSReader\vtkCGNSReader.cxx, line 1001
vtkCGNSReader (00000292A30283A0): Not enough coordinates in node GridCoordinates
ERROR: In C:\glr\builds\paraview\paraview-ci\build\superbuild\paraview\src\VTKExtensions\CGNSReader\vtkCGNSReader.cxx, line 2828
vtkCGNSReader (00000292A30283A0): Could not allocate memory for connectivity
ERROR: In C:\glr\builds\paraview\paraview-ci\build\superbuild\paraview\src\VTKExtensions\CGNSReader\vtkCGNSReader.cxx, line 4561
vtkCGNSReader (00000292A30283A0): Error Reading file
ERROR: In C:\glr\builds\paraview\paraview-ci\build\superbuild\paraview\src\VTK\Common\ExecutionModel\vtkExecutive.cxx, line 753
vtkPVCompositeDataPipeline (00000292AC5098A0): Algorithm vtkCGNSFileSeriesReader(00000292AC4CA8A0) returned failure for request: vtkInformation (00000292B9BA8580)
Debug: Off
Modified Time: 418111
Reference Count: 1
Registered Events: (none)
Request: REQUEST_DATA
FORWARD_DIRECTION: 0
ALGORITHM_AFTER_FORWARD: 1
FROM_OUTPUT_PORT: 0
The idea here is several solution files may be written for a single mesh, so the mesh should be linked in to avoid duplicating very large meshes. CGNS check reports the same results for both files and CGNSView shows the two files are identical when links are followed and when the diff tool is used.
Is it as simple as ParaView does not support links in CGNS files, or is something else going on here? I can provide an input file if it’s the latter. Thanks!
