I have a method of selecting cells and changing the values in that portion of the array to a new integer, but it is quite cumbersome. So, for example, I might have a mesh that has a “Region” cell array with all integer 1 values. I want to select a portion of this and give that selected portion of the “Region” cell array value 2 (or some other pre-defined user integer value).
I’m hoping that either there is a better way in general, or since this method was created a decade ago, that new features may be able to improve this workflow. Currently, I am using two programmable filters to accomplish this. The first is to give each a global ID for when I split up the mesh:
input = self.GetInputDataObject(0,0)
output = self.GetOutputDataObject(0)
numCells = input.GetNumberOfCells()
globalIds = vtk.vtkDoubleArray()
globalIds.SetNumberOfValues(numCells)
globalIds.SetName("GlobalIds")
origMats = input.GetCellData().GetArray("Region")
matIds = vtk.vtkDoubleArray()
matIds.SetNumberOfValues(numCells)
matIds.SetName("Region")
for ii in range(numCells):
globalIds.InsertValue(ii,ii)
matIds.InsertValue(ii, int(origMats.GetTuple1(ii)))
output.GetCellData().AddArray(globalIds)
output.GetCellData().AddArray(matIds)
I then have to select a region, then extract that region, and then select that new region plus the original regionIds, and use the next custom filter to change the material:
#Changes material of selected region to
#the value set here
matID = 2
#Just in case this needs to be done on
#data formatted differently
array = 'Region'
def getSelection(sel, obj):
currentCell = vtk.vtkGenericCell()
oldPts = sel.GetCellData().GetArray("GlobalIds")
pointsToChange = []
for ii in range(sel.GetNumberOfCells()):
pointsToChange.append(int(oldPts.GetTuple1(ii)))
return pointsToChange
inp1 = self.GetInputDataObject(0,0)
inp2 = self.GetInputDataObject(0,1)
num1 = inp1.GetNumberOfCells()
num2 = inp2.GetNumberOfCells()
if num1 > num2:
toChange= getSelection(inp2, inp1)
output.DeepCopy(inp1)
else:
toChange= getSelection(inp1, inp2)
output.DeepCopy(inp2)
oldIds = output.GetCellData().GetArray(array)
for ii in toChange:
oldIds.SetComponent(ii, 0, float(matID))
As I previously stated, this can become quite cumbersome when it’s necessary to do it over and over. Are there any potential ways to speed up or streamline this workflow?
Thanks!
