clean to grid taking a long time
I am running a 2D transient simulation and visualizing with paraview
following some recommendations here I am beginning my pipeline with “clean to grid”. however now whenever I move between frames the process takes about 2-3 minutes. furthermore the cleaning is not “saved” when move back to frames that I already saw. is there a way to clean all the frames, let it run for as long as it takes but then be able to work smoothly?
many thanks
Nathan
Hi @nathanbl ,
You can either:
  • Save the results of the “Clean to Grid” to disk and open it again
  • Add a “Temporal Cache” filter
Thank you for the answer Mathieu, how should I save the results? I am working with windows. when I save the state the “clean to grid” process is not saved.
Use File → SaveData
Thank you Mathieu, this works!
