You can use the ParaView widgets (i.e.: Box) to control filters with ParaViewWeb but it is not that straight forward to use them.
Here is a code snippet that should help you get 80% there.
from paraview import simple
# Helper methods
# Widget:
# - Visibility
# - Enabled
# - MoveFacesEnabled
# - RotationEnabled
# - ScalingEnabled
# - TranslationEnabled
# - PlaceFactor
# - PlaceWidget
# - Position
# - PositionInfo
# - Rotation
# - RotationInfo
# - Scale (or Length, pv 5.7+)
# - ScaleInfo
# Box: ['Bounds', 'Input', 'Position', 'Rotation', 'Scale']
def _box_update_widget(self, widget):
widget.Position = self.Position
widget.Rotation = self.Rotation
if not hasattr(self, 'Length'):
widget.Scale = self.Scale
else:
widget.Scale = self.Length
# update all the information-only properties together.
widget.UpdatePropertyInformation()
widget.UpdateVTKObjects()
def _box_widget_update(self, obj, event):
self.GetProperty('Position').Copy(obj.GetProperty('PositionInfo'))
self.GetProperty('Rotation').Copy(obj.GetProperty('RotationInfo'))
self.GetProperty('Scale').Copy(obj.GetProperty('ScaleInfo'))
else:
self.GetProperty('Length').Copy(obj.GetProperty('ScaleInfo'))
self.UpdateVTKObjects()
def _expandBounds(bounds):
size = [0.02*abs(bounds[1] - bounds[0]),
0.02*abs(bounds[3] - bounds[2]),
0.02*abs(bounds[5] - bounds[4])]
return [bounds[0] - size[0], bounds[1] + size[0],
bounds[2] - size[1], bounds[3] + size[1],
bounds[4] - size[2], bounds[5] + size[2]]
# Public API
def updateWidgetStyle(wRep):
# wRep.GetOutlineProperty().SetColor(...)
# wRep.GetSelectedOutlineProperty().SetColor(...)
# wRep.GetHandleProperty().SetColor(...)
# wRep.GetFaceProperty().SetColor(...)
# wRep.GetSelectedFaceProperty().SetColor(...)
# wRep.GetSelectedHandleProperty().SetColor(...)
pass
def setBoxWidgetBounds(sourceProxy, widgetProxy, dataBounds, options):
widgetVTKRep = widgetProxy.GetRepresentationProxy().SMProxy.GetClientSideObject()
dataBounds = _expandBounds(dataBounds)
if hasattr(widgetProxy, 'UseReferenceBounds'):
# PV 5.6+
sourceProxy.UseReferenceBounds = 1
sourceProxy.Bounds = dataBounds
widgetProxy.UseReferenceBounds = 1
widgetProxy.ReferenceBounds = dataBounds
widgetProxy.UpdatePropertyInformation()
widgetProxy.UpdateVTKObjects()
else:
# PV 5.6
widgetVTKRep.PlaceWidget(dataBounds)
if options:
if 'reset' in options and options['reset']:
sourceProxy.Position = [0, 0, 0]
sourceProxy.Rotation = [0, 0, 0]
if not hasattr(sourceProxy, 'Length'):
sourceProxy.Scale = [1, 1, 1]
else:
sourceProxy.Length = [1, 1, 1]
sourceProxy.UpdateWidget(widgetProxy)
sourceProxy.UpdateVTKObjects()
def createBoxWidget(sourceProxy, viewProxy, dataBounds):
widgetProxy = simple.servermanager.rendering.BoxWidgetRepresentation(
MoveFacesEnabled = 1,
RotationEnabled = 1,
ScalingEnabled = 0,
TranslationEnabled = 1,
# Use custom colors for widget representation
updateWidgetStyle(widgetVTKRep)
viewProxy.Representations.append(widgetProxy)
widgetProxy.Visibility = 1
widgetProxy.Enabled = 1
setBoxWidgetBounds(sourceProxy, widgetProxy, dataBounds, None)
# Attach helper method to source proxy
setattr(sourceProxy.__class__, 'UpdateWidget', _box_update_widget)
setattr(sourceProxy.__class__, 'WidgetUpdate', _box_widget_update)
widgetProxy.GetProperty('PlaceFactor').SetData(1.0)
sourceProxy.Observed = widgetProxy
sourceProxy.ObserverTag = widgetProxy.AddObserver("EndInteractionEvent", sourceProxy.WidgetUpdate)
return widgetProxy
