Clip with max and min
Dear all,
When doing a clip with Clip Type=Scalar, a single value is asked. The clip is the done from the minimum value in the range to the chosen value, or from the chosen value to the max value in the range clicking “Invert”.
Is there a way to obtain a clip between two given values?
Best,
You can try the Threshold filter.
Use the Iso Volume filter.
thank you for the replies, I also found out that using the Clip twice does the job!
