Hi, I just updated from Paraview 5.6 to 5.7. I had it configured to work with an existing conda python environment. It seems that if on opening a new Matplotlib plot along the lines of the following:
import matplotlib.pyplot as plt
fig, ax = plt.subplots(nrows=2, ncols=1)
plt.show()
- on closing the plot, a TypeError is thrown:
File “”, line 1, in
File “/home/tjim/anaconda3/envs/sound6/lib/python3.7/site-packages/matplotlib/pyplot.py”, line 269, in show
return _show(*args, **kw)
File “/home/tjim/anaconda3/envs/sound6/lib/python3.7/site-packages/matplotlib/cbook/deprecation.py”, line 413, in wrapper
return func(*args, **kwargs)
File “/home/tjim/anaconda3/envs/sound6/lib/python3.7/site-packages/matplotlib/backend_bases.py”, line 3309, in show
cls.mainloop()
File “/home/tjim/anaconda3/envs/sound6/lib/python3.7/site-packages/matplotlib/backends/backend_qt5.py”, line 1100, in mainloop
signal.signal(signal.SIGINT, old_signal)
File “/home/tjim/anaconda3/envs/sound6/lib/python3.7/signal.py”, line 47, in signal
handler = _signal.signal(_enum_to_int(signalnum), _enum_to_int(handler))
TypeError: signal handler must be signal.SIG_IGN, signal.SIG_DFL, or a callable object
This happens if I run it from a script (i.e. pvpython test.py) or in a pvpython interpreter. At first, I suspected the QT module and have recompiled several times with different QT configurations and environment variables but I still got the same error. To confirm that it wasn’t me messing up the compilation, I also created a fresh Python 3.7 environment pulled the latest Conda-Forge build. It still produces this error on closing plots. Can you help me diagnose the issue? It doesn’t throw this error if I run the ‘ordinary python’, as oposed to pvpython (using the same libraries, I believe).
I also tried with PV 5.8.0-RC1 and it still seems to have this problem.
Thanks and regards,
Tim
