Dear All, @ben.boeckel
I have a little CMake problem that I could not solve so far. I have C Code in my plugin, and need to pass the location of two external header files to it. They are both located in the same directory. The path ${ECCODES_INCLUDE_DIRS} is correct,  but passing this to the C code (cdilib.c) does not work. An object file for the C++ code is created however. I tried several variations and googled a bit, but I haven’t solved it yet. Below is the CMakeLists.txt, any help is appreciated:
Thanks and Cheers, Niklas
set(classes
vtkCDIReader)
set(sources
cdilib.c
HEADERS ${ECCODES_INCLUDE_DIRS})
set(private_headers
cdi.h)
set(CMAKE_C_STANDARD 99)
vtk_module_add_module(CDIReader::vtkCDIReader
CLASSES ${classes}
SOURCES ${sources}
PRIVATE_HEADERS ${private_headers} ${ECCODES_INCLUDE_DIRS})
if (PARAVIEW_PLUGIN_BUILD_CDIReader_WITH_GRIB)
vtk_module_link(CDIReader::vtkCDIReader
PRIVATE
${ECCODES_LIBRARIES})
endif ()
vtk_module_definitions(CDIReader::vtkCDIReader
PRIVATE
# Please leave these definitions in here and do not change them.
# We use the cdi library to read both, netCDF2 and netCDF4 data,
# and if configured and available, also grib data (see below).
HAVE_LIBNETCDF
HAVE_NETCDF2
HAVE_NETCDF4)
PRIVATE
HAVE_LIBGRIB_API)
endif ()
paraview_add_server_manager_xmls(
XMLS  CDIReader.xml)
