I’m trying to build ParaView in MacOS. I went to the repository https://gitlab.kitware.com/paraview/paraview/tree/master which lead me to build paraview-superbuild
`https://gitlab.kitware.com/paraview/paraview-superbuild/tree/v5.7.0``
Following instructions I executed
$ cd paraview-superbuild
$ git fetch origin # ensure you have the latest state from the main repo
$ git checkout v5.7.0 # replace `v5.7.0` with tag name of your choice
$ git submodule update
Then
$ mkdir build
$ cd build
$ cmake ..
And I’m getting the error
-- Found Git: /usr/local/bin/git (found version "2.21.0")
-- Determined source version for paraview: 5.7.0
CMake Error at superbuild/cmake/SuperbuildMacros.cmake:481 (message):
The build tree appears to be inside of the git repository located at
/Users/username/Desktop/dev/paraview/paraview-superbuild. This interferes
with the way the superbuild applies patches to projects and is not
supported. Please relocate the build tree to a directory which is not
under a git repository.
What is happening here? Was cmake execute in the right folder? because there are more CMakeList.txt inside paraview-superbuild.
Thanks!
(wording improvements would be greatly appreciated). Your build tree is under a Git repository checkout (at the path given). We use
