I have attached a contour. As you can see in the Legend, 0 value indicates white color. However, in the contours, I am not getting the same colormap. How to rectify it and remove the radial lighting?
Thank you for your kind support and time.
Would you try the following?
Properties > Lighting:
Thanks a lot! It worked
You can also disable the lighting completely (via lightinspector).
