Hey All,
I’m trying to get ParaView up and running on our system. There are no issues with ccmake during configuration or generation, however, when I actually go to compile the code it fails with the error:
In member function ‘void vtkAOSDataArrayTemplate::SetTupleValue(vtkIdType, const ValueType*)’:
/gpfs/ParaviewSource/ParaView-v5.4.1/VTK/Common/Core/vtkAOSDataArrayTemplate.txx:453:28: error: ‘template<class DerivedT, class ValueTypeT> class vtkGenericDataArray’ used without template parameters
vtkGenericDataArray::SetTypedTuple)
This seems like a fairly standard compilation error, but I haven’t changed anything in the ParaView source code, so I can’t imagine why there should be syntax errors or similar in the code. I have to assume this is caused by some errors in my parameters, but nothing I’ve tried has made a difference.
Thanks
Edit: Just in case anybody is reading this in the future with the same issue, the solution appears to have been to delete the original source code, re-download a fresh copy, and compile that.
