Compilation Error when compiling Paraview 5.8.0
apologize if this issue was already addressed, but I fail to build Paraview 5.8.0 on Debian 9 with 8 GB of RAM and gcc version 6.3.0.
Paraview compilation triggers an error in gcc with the error message below.
I tried to build with a fewer number of make jobs (-j 2) but still, I get a compilation error.
Is this a known issue?
Thanks.
Compilation error reads:
g++: internal compiler error: Processus arrêté (program cc1plus)
Please submit a full bug report,
with preprocessed source if appropriate.
See <file:///usr/share/doc/gcc-6/README.Bugs> for instructions.
VTK/Accelerators/Vtkm/CMakeFiles/AcceleratorsVTKm.dir/build.make:143 : la recette pour la cible « VTK/Accelerators/Vtkm/CMakeFiles/AcceleratorsVTKm.dir/vtkmClip.cxx.o » a échouée
make[2]: *** [VTK/Accelerators/Vtkm/CMakeFiles/AcceleratorsVTKm.dir/vtkmClip.cxx.o] Erreur 4
https://gitlab.kitware.com/paraview/paraview/issues/19483
make -j 1 should work, or you can use ninja as well.
thanks for the prompt feedback. I will report about the status. Just started a new compilation.
I confirm that make -j 1 does the job. Thanks
