Is it possible to create a resultant vector on the surface from, let’s say, y components. I want to check the resultant vector of the reaction forces on a surface.
Use Calculator filter for that.
I used the calculator to have only components. There are now y components at each node. I want to have sum of all the components on one surface. Any idea what I am doing wrong regarding the resultant. Also how do I select one surface. It looks like following right now. It is a simple cantilever beam problem.
Please share your data and explain clearly what you are trying to achieve
