I created a custom docker image (see the dockerfile below) and ran the image in codespace linux environment. I followed this documentation to setup the launch.config and 001-pvw.conf file.
https://kitware.github.io/paraview-lite/docs/index.html
I can open the frontend page, but couldnt connect to the paraview (click connect button). I feel like the paraview app did not initialized. only the web page was launched. not sure if thats true.
this is the command I used to build the docker image
docker build -t paraview-multiuser:5.10.0-osmesa .
this is the command I used to run the container
docker run -p 8080:80 -p 9000:9000 paraview-multiuser:5.10.0-osmesa
then open
http://localhost:8080/
What did I miss here? please give me some guidance.
here is the dockerfile I created.
# Use a lightweight Ubuntu base image
FROM ubuntu:20.04
# Set environment variables to make `tzdata` install without prompts
ENV DEBIAN_FRONTEND=noninteractive
# Install required packages, including Apache and APR development packages
RUN apt-get update && apt-get install -y \
    wget \
    apache2 \
    apache2-dev \
    libapr1-dev \
    apache2-utils \
    libglapi-mesa \
    libosmesa6 \
    libglu1-mesa \
    python3 \
    python3-pip \
    && apt-get clean && rm -rf /var/lib/apt/lists/*
# Download and extract the new ParaView 5.11 package with OSMesa and Python 3.9
RUN wget https://www.paraview.org/files/v5.10/ParaView-5.10.0-osmesa-MPI-Linux-Python3.9-x86_64.tar.gz && \
    tar -xzf ParaView-5.10.0-osmesa-MPI-Linux-Python3.9-x86_64.tar.gz -C /opt && \
    rm ParaView-5.10.0-osmesa-MPI-Linux-Python3.9-x86_64.tar.gz
# Set up environment paths for ParaView binaries
ENV PATH="/opt/ParaView-5.10.0-osmesa-MPI-Linux-Python3.9-x86_64/bin:$PATH"
# Install wslink and Twisted for the Python launcher
RUN pip3 install wslink twisted
# Set up proxy/mapping file with permissions
RUN mkdir -p /opt/proxy-mapping /opt/viz-logs && \
    touch /opt/proxy-mapping/proxy.txt && \
    groupadd mappingfileusers && \
    usermod -a -G mappingfileusers www-data && \
    chgrp mappingfileusers /opt/proxy-mapping/proxy.txt && \
    chmod 660 /opt/proxy-mapping/proxy.txt
# Copy the launcher configuration
COPY launcher.config /opt/proxy-mapping/launcher.config
# Copy Apache configuration for the virtual host and proxy
COPY 001-pvw.conf /etc/apache2/sites-available/001-pvw.conf
# Enable necessary Apache modules and the new site configuration
RUN a2enmod vhost_alias proxy proxy_http proxy_wstunnel rewrite && \
    a2ensite 001-pvw
# Expose the ports needed for Apache, ParaView, and the Python launcher
EXPOSE 80 8080 9000
# Start Apache, ParaView Lite, and the launcher in the background
CMD apachectl -D FOREGROUND & \
    python3 -m wslink.launcher /opt/proxy-mapping/launcher.config
here is the launcher.config file.
  "configuration": {
    "host": "localhost",
    "port": 9000,
    "endpoint": "paraview",
    "content": "/opt/ParaView-5.10.0-osmesa-MPI-Linux-Python3.9-x86_64/share/paraview-5.10/web/lite/www",
    "proxy_file": "/opt/proxy-mapping/proxy.txt",
    "sessionURL": "ws://localhost/proxy?sessionId=${id}&path=ws",
    "timeout": 25,
    "log_dir": "/opt/viz-logs",
    "fields": ["file", "host", "port", "updir"]
  "resources": [
    { "host": "localhost", "port_range": [9001, 9003] }
  "properties": {
    "dataDir": "/data",
    "lite_path": "/opt/ParaView-5.10.0-osmesa-MPI-Linux-Python3.9-x86_64/share/paraview-5.10/web/lite",
    "python_exec": "/opt/ParaView-5.10.0-osmesa-MPI-Linux-Python3.9-x86_64/bin/pvpython"
  "apps": {
    "paraview-lite": {
      "cmd": [
        "${python_exec}", "--dr", "${lite_path}/server/pvw-lite.py",
        "--port", "${port}",
        "--data", "${dataDir}",
        "--authKey", "${secret}"
      "ready_line": "Starting factory"
here is the 001-pvw.conf file.
<VirtualHost *:80>
    ServerName localhost
    ServerAdmin webmaster@example-host.example.com
    DocumentRoot /opt/ParaView-5.10.0-osmesa-MPI-Linux-Python3.9-x86_64/share/paraview-5.10/web/lite/www
    ErrorLog ${APACHE_LOG_DIR}/error.log
    CustomLog ${APACHE_LOG_DIR}/access.log combined
    # Rule to forward ParaViewWeb launcher requests
    ProxyPass /paraview http://localhost:9000/paraview
    ProxyPassReverse /paraview http://localhost:9000/paraview
    # Enable session-based proxying for multi-user
    RewriteEngine On
    RewriteMap session-to-port txt:/opt/proxy-mapping/proxy.txt
    RewriteCond %{QUERY_STRING} ^sessionId=(.*)&path=(.*)$ [NC]
    RewriteRule ^/proxy.*$ ws://${session-to-port:%1}/%2 [P]
    <Directory "/opt/ParaView-5.10.0-osmesa-MPI-Linux-Python3.9-x86_64/share/paraview-5.10/web/lite/www">
        Options Indexes FollowSymLinks
        AllowOverride None
        Require all granted
    </Directory>
</VirtualHost>
