I am trying to run paraview web from office system (using ssh from local system) and wanted to view the visualization from local browser and with different server name. To this, I modified the apache2 config file and launcher file as below.
Apach2 001-pvw.conf - Here I am using servername as testpvw
<VirtualHost *:80>
ServerName testpvw
ServerAdmin sunag.ra@niramai.com
DocumentRoot /home/data/www
ErrorLog /home/data/logs/apache_error.log
CustomLog /home/data/logs/apache_access.log combined
<Directory /home/data/www/>
Options Indexes FollowSymLinks
Order allow,deny
Allow from all
AllowOverride None
Require all granted
</Directory>
# Handle launcher forwarding
ProxyPass /paraview http://localhost:8080/paraview
# Handle WebSocket forwarding
RewriteEngine On
RewriteMap session-to-port txt:/home/data/proxy.txt
RewriteCond %{QUERY_STRING} ^sessionId=(.*)&path=(.*)$ [NC]
RewriteRule ^/proxy.*$ ws://${session-to-port:%1}/%2 [P]
</VirtualHost>
Launcher.json file - Here I am using the servername “testpvw” and placed in sessionURL as host
"resources": [ {"port_range": [9001, 9103], "host": "localhost"} ],
"configuration": {
"log_dir": "/home/data/pvw/logs",
"host": "localhost",
"proxy_file": "/home/data/proxy.txt",
"endpoint": "paraview",
"sessionURL": "ws://testpvw:80/proxy?sessionId=${id}&path=ws",
"timeout": 5,
"fields": ["host", "port"],
"port": 8080
"properties": {
"web_path": "/home/data/pv/pv-5.9.0/share/paraview-5.9/web",
"python_exec": "/home/data/pv/pv-5.9.0/bin/pvpython",
"dataDir": "/home/data/pvw"
"apps": {
"paraview-lite": {
"cmd": [
"${python_exec}",
"${web_path}/lite/server/pvw-lite.py",
"--port", "${port}",
"--data", "${dataDir}/${data}",
"--authKey", "${secret}"
"ready_line" : "Starting factory"
When I run the web link as
http://testpvw/litenothing displays and when I runhttp://<ip-address>/lite, the paraview lite page displays. When I click “connect to paraview”, it showsConnection error. -
The logs are displayed for running
http://<ip-address>/liteas follows:
a. launcherLog.log
2021-10-27 16:45:49,878:INFO:root:Post started
2021-10-27 16:45:49,878:INFO:root:{'application': 'paraview-lite'}
2021-10-27 16:45:49,878:INFO:root:request contents
2021-10-27 16:45:49,878:INFO:root:Create new session
2021-10-27 16:45:49,892:INFO:root:inside createSession id: 3d9a058c-3717-11ec-a748-d89ef315cbb6
2021-10-27 16:45:49,892:ERROR:root:Some properties could not be resolved: /home/data/pvw/${data}
2021-10-27 16:45:49,892:INFO:root:Session created
2021-10-27 16:45:54,899:INFO:twisted:"127.0.0.1" - - [27/Oct/2021:11:15:53 +0000] "POST /paraview/ HTTP/1.1" 200 175 "http://25.13.89.142/lite/" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/91.0.4472.106 Safari/537.36"
b. The log creates a new txt file which contains:
wslink: Starting factory
CRITICAL:twisted:wslink: Starting factory
c. The apache_access.log or apache_error.log does not give any feedback to it.
So my question is,
- How to host the pvw with diffrent servername from local browser running in ssh server.?
- What work around should be done in order to connect the apache2 and launcher so that the apache is accessed?
Regards,
Sunag R A.
