Connectivity filter for parallel files (PVTU)
My dataset consists of multiple spheres within a large cylinder. I need to integrate scalars within the individual spheres and extract results. I can do this in serial using the following workflow:
  1. Open
  2. Connectivity Filter
  3. Threshold Filter
  4. Integrate Variables Filter
But this gives me bad results when dealing with parallel vtk files (PVTU), thanks to the split vtu files counting as separate regions.
Currently, there are no ghost elements in the VTU files that I use.
Is there a way to get the connectivity filter to ignore the vtu splits? I tried using cleanToGrid but it ends up merging everything into a monolithic cylinder. Is there a way to merge ONLY the partitioned vtu data from pvtu files?
Thanks!
ParaView 5.9 will add a mode to the Merge Blocks filter that merges only pieces in a multipiece data set. That should do what you are looking for if I am not mistaken. @utkarsh.ayachit, can you verify that will apply in this case?
Sounds about right, but I’m clueless about the implementation. But Merge Blocks doesn’t apply to pvtu files, right?
Does this mean the procedure is:
  1. Open PVTU in Parallel
  2. ProcessIds
  3. Threshold for each ID
  4. Merge Blocks
or is there a way to make it directly apply to a PVTU file?
Also, is there a date for the 5.9 release?
Thanks, again!
D’oh, right. Sorry, Merge Blocks only applies to multiblock datasets. I suppose you could use the Group filter, then Merge Blocks with the single-block dataset, then Extract Block to get it out. That’s a pretty ugly workflow, though. A separte Merge Pieces filter would be easier to use.
Date of the 5.9 release is slated for sometime before Supercomputing 2020 (there is no set date).
Hi Cory,
Just following up on any possible updates. Has something like Merge Pieces been implemented yet?
To reiterate, I have a cylinder filled with spheres, and I’d like to use Integrate Variables on every sphere. Extracting the sphere is possible in serial mode using the Connectivity filter. However, if the data is distributed over several files, the Connectivity filter separates out the partitions, and not the spheres from the cylinders.
Additionally, is it possible to apply Integrate Variables in parallel over multiple objects? Currently I resort to using Threshold to individually separate and loop over every object.
