I am having a visualization issue when I try to visualize a threshold isosurface (in my case it is Level set = 0 for multiphase flow). I notice the surface is broken where my domain is decomposed (MPI blocks). The surface here is a threshold taken after the “Cell data to Point data” filter is applied.
Any tips or suggestions on getting a smooth or at least continuous surface across MPI blocks??
Thanks in advance!
Hi @Andre_Calado and welcome to discourse !
Try applying the Ghost Cell Generator filter before applying contour. This will exchange the appropriate data across the interface which should result into a continuous isosurface.
Thanks @Christos_Tsolakis . I tried using it but it still looks a bit odd…
Is there a specific order of the filters? Right now I am applying the Ghost cell after the Cell data to point data, and then doing the contour.
Can you share a screenshot ?
Yes the order is important. Try to move the Ghost Cell generator before the cell data to point data filter. Also, I would experiment with the Minimum number of Ghosts option.
Found a solution that works
MergeBlocks > Ghost Cell Generator > Cell Data to Point Data > Contour
