Sonia0.1000.csv (127.8 KB)
Scour Image.pdf (317.1 KB)
I have a image of contour in paraview
i WANT TO plot this in python
how to extract the data.?
at the same tyme these csv file i have some data after running
i want to plot the bed topograpgrpy and images that are in pdf
how to do that
Hello @Sonia
To export the result of your slice, you should select it in the pipeline browser then use the menu File->Save Data… then select csv file format.
To extract to a pdf file, you may use the File->Export Scene menu then select pdf file format.
Hope this helps!
Best Regards
