I have STL file imported in paraview and also have ttl imported and i want to generate contour tree and line in the mesh but FTM filter is disabled when i try to select it.
First question, are you sure that your mesh only contains triangle ? If not, you may want to use Tesselate / Tetrahedralize to enforce this.
Then, the contour tree is defined on a mesh with a scalar field. It seems there is none in your current data set. If you want to use the Z-coordinate as a scalar field, you can simply add an elevation filter, setup to use the Z axis. The contour tree should be available then.
