Conversion of unstructured points to a connected unstructured grid (auto add edges)
That is not the case. ParaView will show you the surface, but if you cut the resulting mesh with a Clip filter and look at the interior of the result of Delaunay3D, you will see the tetrahedral mesh.
Alternatively, you can extract all edges in the dataset with the Extract Edges filter to see all the edges you were expecting.
