I am a beginner in paraview,
I am trying to convert a .vtk Data file (DATASET POLYDATA) to a 3D voxel-based image having a .raw or .tif format. So I need to voxelise the domain(sample of particles) and to saved the data into a binary file (.raw or .tif) consisting of voxels with a value of either 0 or 255 which represent if the voxel is inside a particle or in a void space.
The .vtk file corresponds to slices of ellipsoid particles taken from a DEM software.
I was searching and I found that it could be possible to do using DataSet Resampling Filters but this function was disabled in my case.
I am using paraview 5.0.1
Thank you for helping me.
Here is an example for the data of a .vtk file of 1 particle with only three slices (to reduce the data):
# vtk DataFile Version 2.0
Sway data processing
ASCII
DATASET POLYDATA
POINTS 18 float
0.0027844392648 0.00563003547056 0.00338288761005
-0.00244453183833 -4.5732163164e-05 0.00509855744152
-0.0055502958195 0.00307391120888 0.00413183342481
-0.00548856609027 0.00336799271205 0.00164995802301
-0.00232107237987 0.000542430843166 0.000134806637937
0.0007846916013 -0.00257721252888 0.00110153065465
0.000722961872072 -0.00287129403205 0.00358340605645
-0.007550043483 -0.00513333679056 0.00185047646941
POLYGONS 12 60
4 0 1 7 6
4 1 2 8 7
4 2 3 9 8
4 3 4 10 9
4 4 5 11 10
4 5 0 6 11
4 6 7 13 12
4 7 8 14 13
4 8 9 15 14
4 9 10 16 15
4 10 11 17 16
4 11 6 12 17
