I have the following CSV file:
x,y,z,Temp
0,0,0,1
4,0,0,2
0,4,0,3
4,4,0,4
0,0,8,5
4,0,8,6
0,4,8,7
I import it into ParaView using the standard CSV reader. Then I try to apply the Table to Points filter, select the appropriate X, Y and Z columns and then I get an error thrown. This is with 5.10.1 version (both ARM64 and x64 versions on macOS).
vtkTableToPolyData (0x600000ccc000): Failed to locate the columns to use for the point coordinates
ERROR: In /opt/glr/paraview/paraview-ci/build/superbuild/paraview/src/VTK/Common/ExecutionModel/vtkExecutive.cxx, line 753
vtkPVCompositeDataPipeline (0x600000e06140): Algorithm vtkTableToPolyData(0x600000ccc000) returned failure for request: vtkInformation (0x6000029b6480)
Debug: Off
Modified Time: 458315
Reference Count: 1
Registered Events: (none)
Request: REQUEST_DATA
FROM_OUTPUT_PORT: 0
ALGORITHM_AFTER_FORWARD: 1
FORWARD_DIRECTION: 0```
Anyone have any ideas?
4,4,8,8
