Solution / Workaround
Part 1: Delete faulty plugin
Deleting the faulty platformtheme plugin workaround the issue
cd /home/jcfr/Software/Qt5.10.0/5.10.0/gcc_64/plugins
mkdir ./platformthemes_disabled
mv ./platformthemes/libqgtk3.so ./platformthemes_disabled/
Part 2: Rename Qt5Gui_QGtk3ThemePlugin.cmake
mv lib/cmake/Qt5Gui/Qt5Gui_QGtk3ThemePlugin.cmake lib/cmake/Qt5Gui/Qt5Gui_QGtk3ThemePlugin.cmake_disabled
This will prevent the following error from being reported:
CMake Error at /home/jcfr/Software/Qt5.10.0/5.10.0/gcc_64/lib/cmake/Qt5Gui/Qt5GuiConfig.cmake:15 (message):
The imported target "Qt5::Gui" references the file
"/home/jcfr/Software/Qt5.10.0/5.10.0/gcc_64/plugins/platformthemes/libqgtk3.so"
but this file does not exist. Possible reasons include:
* The file was deleted, renamed, or moved to another location.
* An install or uninstall procedure did not complete successfully.
* The installation package was faulty and contained
"/home/jcfr/Software/Qt5.10.0/5.10.0/gcc_64/lib/cmake/Qt5Gui/Qt5Gui_QGtk3ThemePlugin.cmake"
but not all the files it references.
Analysis
After analyzing the core dump (see details below), I found out that paraview was picking up the wrong library for protobuf.
The library /usr/lib/x86_64-linux-gnu/libmirprotobuf.so.3 was loaded instead of the one built by paraview.
In that case, the library incorrect protobuf runtime was indirectly loaded by Qt5 platformtheme plugin libqgtk3:
$ cd /home/jcfr/Software/Qt5.10.0/5.10.0/gcc_64/plugins
$ for f in $(find . | ack "so$"); do ldd $f | ack "libmirprotobuf" && echo "$f"; done
libmirprotobuf.so.3 => /usr/lib/x86_64-linux-gnu/libmirprotobuf.so.3 (0x00007f3709f2f000)
Crash Backtrace
#0 0x00007fac1b1cc1c7 in __GI_raise (sig=sig@entry=6) at ../sysdeps/unix/sysv/linux/raise.c:55
#1 0x00007fac1b1cde2a in __GI_abort () at abort.c:89
#2 0x00007fac13659b10 in google::protobuf::internal::LogMessage::Finish (this=0x7ffe73fad1b0) at /home/jcfr/Projects/ParaView/ThirdParty/protobuf/vtkprotobuf/src/google/protobuf/stubs/common.cc:195
#3 0x00007fac13659b18 in google::protobuf::internal::LogFinisher::operator= (this=this@entry=0x7ffe73fad16f, other=...) at /home/jcfr/Projects/ParaView/ThirdParty/protobuf/vtkprotobuf/src/google/protobuf/stubs/common.cc:200
#4 0x00007fac13659d1d in google::protobuf::internal::VerifyVersion (headerVersion=2006001, minLibraryVersion=<optimized out>, filename=0x7fabedf778c0 "/build/mir-n3hlNX/mir-0.17.0+15.10.20151008.2/src/protobuf/google_protobuf_guard.cpp") at /home/jcfr/Projects/ParaView/ThirdParty/protobuf/vtkprotobuf/src/google/protobuf/stubs/common.cc:69
#5 0x00007fabedf4e2ca in ?? () from /usr/lib/x86_64-linux-gnu/libmirprotobuf.so.3
#6 0x00007fac1f21b5ca in call_init (l=<optimized out>, argc=argc@entry=1, argv=argv@entry=0x7ffe73fae0d8, env=env@entry=0x7ffe73fae0e8) at dl-init.c:72
#7 0x00007fac1f21b6db in call_init (env=<optimized out>, argv=<optimized out>, argc=<optimized out>, l=<optimized out>) at dl-init.c:30
#8 _dl_init (main_map=main_map@entry=0x22b1a90, argc=1, argv=0x7ffe73fae0d8, env=0x7ffe73fae0e8) at dl-init.c:120
#9 0x00007fac1f220597 in dl_open_worker (a=a@entry=0x7ffe73fad608) at dl-open.c:579
#18 0x00007fac1bfaacae in QFactoryLoader::instance(int) const () from /home/jcfr/Software/Qt5.10.0/5.10.0/gcc_64/lib/libQt5Core.so.5
#19 0x00007fac1c5ae029 in QPlatformThemeFactory::create(QString const&, QString const&) () from /home/jcfr/Software/Qt5.10.0/5.10.0/gcc_64/lib/libQt5Gui.so.5
#24 0x00007fac1cdd2369 in QApplicationPrivate::init() () from /home/jcfr/Software/Qt5.10.0/5.10.0/gcc_64/lib/libQt5Widgets.so.5
#25 0x00000000004096e9 in main (argc=1, argv=0x7ffe73fae0d8) at /home/jcfr/Projects/ParaView-RelWithDebInfo/Applications/ParaView/paraview_main.cxx:104
