Crash when trying to volume render or clip unstructured grid data
I’m trying to visualize a cloud collapse using Paraview, the original data is generated by an SPH program and the output is transformed into a vtk unstructured grid format. This has worked well for previous simulation work (with higher resolution), however compared to the cloud collapse my previous work have not exhibited a large range of densities and thereby not a large range of different cell sizes. The cloud collapse simulation involves densities that range over several orders of magnitude.
Surface, wireframe, and point rendering works, however, trying to apply any clipping or changing to volume rendering for this simulation crashes Paraview. I have also tried to resample it to image file(within Paraview) but this also crashes Paraview. I can get it to work if I limit the box and remove the very high and low density regions. My knowledge about visualization techniques is quite limited, but I’m guessing that there might be some issue with using a large range of different cell sizes for the volume rendering? Is this just a memory issue? And if so, why can’t I clip or resample the data to an image file? The data files are not very large (around 200mb).
Delaunoy triangulation generated by qhull first from SPH point data and then turned into vtk format with the attached file delaunayVTK.cpp (3.9 KB) . I have also attached the crash log from my Mac crash.log (123.3 KB) . The same crashes occurs on my Windows machine aswell (i9 9900k, 16gb ram, Nvidia RTX 2090).
Please share your data so we can test with it.
Here is the full vtk datafile:
And a reduced version:
This site require signin. Please share using another service.
Sorry, I have updated the links above.
I reproduce but there is probably issues in your files.
How did you produce these files ?
SPH point data qhullParticles.txt with following format:
3
7723247
-0.000178 -0.000099 -0.007983
-0.000177 0.000095 -0.007965
-0.000046 -0.000793 -0.007945
SPH scalar field data qhullFields.txt with following format:
3
7723247
16.989479 16.989479
17.084078 17.084078
17.499884 17.499884
qhull tetrahedron data qhullTetrahedra.txt containing face data with following format:
50346662
3104067 2924391 3103884 3019059
2924391 2856654 3104067 2642829
250060 305059 232444 286378
7721163 7717105 7721218 7719503
I am having the same problem. I cannot share my data as it is confidential, but it is a micro-CT DICOM stack. I am on Windows and using clip box with volume data causes ParaView to crash and shutdown.
Confidential data can be shared through a NDA:
https://www.kitware.com/what-we-offer/#support
