Crashes in Client Server Mode
I’m running paraview in client server mode but whenever I try to load any solution (.vtu) the server side always crashes and I get the following error message on my laptop
whilst on server side I get the following error:
Mesa warning: failed to remap glVertexAttrib3hvNV
Mesa warning: failed to remap glVertexAttrib4hNV
Mesa warning: failed to remap glVertexAttrib4hvNV
Mesa warning: failed to remap glVertexAttribs1hvNV
Mesa warning: failed to remap glVertexAttribs2hvNV
Mesa warning: failed to remap glVertexAttribs3hvNV
Mesa warning: failed to remap glVertexAttribs4hvNV
Mesa warning: failed to remap glVertexAttrib3hNV
Mesa warning: failed to remap glVertexAttrib1hNV
Mesa warning: failed to remap glVertexAttrib1hvNV
Mesa warning: failed to remap glVertexAttrib2hNV
Mesa warning: failed to remap glVertexAttrib2hvNV
Mesa warning: failed to remap glVertexAttrib1hNVMesa warning: failed to remap glVertexAttrib1hNV
I’ve already checked that the two versions of ParaView I’m using matches (for reference 5.10.1).
How I can solve this issue?
Regards
Hi @Frankx9
Please share your .vtu file
Best,
Hi @mwestphal
here it is Send
It works just fine when I open it locally on my laptop
Regards
Opens fines in ParaView 5.11 on Linux.
Locally it works fine (same file copied on my laptop), the issue is when I try to open it from client mode (i.e. connecting to a cluster where I have those files stored)
I used Client/Server mode, it works fine.
Could you please try with 5.10.1? Is it probably related to ParaView version I’m using?
Works great in 5.10.1 too I’m afraid.
With the errors you shared, you may have a rendering issue on the server side. You should use egl/osmesa version on server side or force client side rendering.
I’m launching it on server side as
mpiexec pvserver
How would you recommend to do ?
The version on server side is 5.10.1-osmesa-MPI-Linux-Python3.9
no need to use mpiexec if you run with a single mpi process. But this is not the issue.
First check with your cluster IT, if they provide paraview this way, there must be a reason.
This should work out of the box, although the warning seems to imply that you are using mesa. Please share Help → About content when connected to the server.
To use client side rendering, just set your “Remote Render Threshold” to the max possible value in Edit- > Settings → RenderView
Client Information:
Version: 5.10.1
VTK Version: 9.0.20210922
Qt Version: 5.15.2
vtkIdType size: 64bits
Embedded Python: On
Python Library Path: /Applications/ParaView-5.10.1.app/Contents/Libraries/lib/python3.9
Python Library Version: 3.9.5 (default, Mar 14 2022, 15:11:26)  [Clang 12.0.0 (clang-1200.0.32.29)]
Python Numpy Support: On
Python Numpy Path: /Applications/ParaView-5.10.1.app/Contents/Python/numpy
Python Numpy Version: 1.21.1
Python Matplotlib Support: On
Python Matplotlib Path: /Applications/ParaView-5.10.1.app/Contents/Python/matplotlib
Python Testing: Off
MPI Enabled: On
ParaView Build ID: superbuild 6dd132601dbb2a9ebdc0d31825989f5b92595b76 (!969)
Disable Registry: Off
Test Directory:
Data Directory:
SMP Backend: Sequential
SMP Max Number of Threads: 1
OpenGL Vendor: Apple
OpenGL Version: 4.1 Metal - 83
OpenGL Renderer: Apple M1 Pro
Connection Information:
Remote Connection: Yes
Separate Render Server: No
Reverse Connection: No
Number of Processes: 48
Disable Remote Rendering: Off
IceT: Off
Tile Display: Off
SMP Backend: TBB
SMP Max Number of Threads: 96
Embedded Python: On
Python Library Path: /apps/paraview/ParaView-5.10.1-osmesa-MPI-Linux-Python3.9-x86_64/lib/python3.9
Python Library Version: 3.9.5 (default, Mar 14 2022, 18:05:58)  [GCC 7.3.1 20180303 (Red Hat 7.3.1-5)]
Python Numpy Path: /apps/paraview/ParaView-5.10.1-osmesa-MPI-Linux-Python3.9-x86_64/lib/python3.9/site-packages/numpy
Python Matplotlib Path: /apps/paraview/ParaView-5.10.1-osmesa-MPI-Linux-Python3.9-x86_64/lib/python3.9/site-packages/matplotlib
OpenGL Vendor: Mesa/X.org
OpenGL Version: 3.3 (Core Profile) Mesa 21.2.1
OpenGL Renderer: llvmpipe (LLVM 7.0.0, 256 bits)
Headless support: OSMesa
Looks correct
@mwestphal
I’ve also done that:
But still getting:
Mesa: User error: GL_INVALID_ENUM in glGetString(GL_EXTENSIONS)
As well as
7f0f2cf86000-7f0f2cf90000 r-xp 00000000 00:28 1225712741                 /apps/paraview/ParaView-5.10.1-osmesa-MPI-Linux-Python3.9-x86_64/lib/libvtkViewsContext2D-pv5.10.so.1
When you’ve opened the foo.vtu file, were you using osmesa or egl version of ParaView?
I just did, works great.
Can you try that locally ?
What should I try? Loading foo.vtu locally on my laptop?
  • Download osmesa version from https://www.paraview.org/download/
  • extract it
  • run the pvserver from it
  • run paraview from the standard version
  • connect to server
  • open your file
I’ll update you as soon as I can
Hi @mwestphal
Just tried but still same issue with Mesa.
At this point I do not know, you should check on another computer.
