crashing when using clip over Image (Uniform Rectilinear Grid)
I am opening a raw image file using the following function:
def readRawFile(volFilePath=‘’,volInfoFilePath=‘’,format=‘.vol’):
if volFilePath[-4:]!=format:
volFilePath+=format
if volInfoFilePath==‘’:
volInfoFilePath=volFilePath+‘.info’
infoValues = {}
with open(volInfoFilePath, “r”) as f:
for line in f:
line = line.strip()
if “=” in line:
key, value = line.split(“=”)
key = key.strip()
value = value.strip()
infoValues[key] = value
imageReaderSource=ImageReader(registrationName=volFilePath.split(‘/’[-1].replace(format,‘’), FileNames=[volFilePath])
imageReaderSource.Set(
DataScalarType=‘float’,
DataByteOrder=‘LittleEndian’,
DataSpacing=[float(infoValues[“voxelSize”]) for i in range(3)],
DataExtent=[0, int(infoValues[“NUM_X”])-1, 0, int(infoValues[“NUM_Y”])-1, 0, int(infoValues[“NUM_Z”])-1],)
UpdatePipeline()
return imageReaderSource,infoValues
and while I am not having issues with slicing the source generated, when I use clip paraview crashes with the following error:
( 76.501s) [paraview ]vtkGenericDataArray.txx:377 ERR| vtkDoubleArray (0x33040200): Unable to allocate 8589934592 elements of size 8 bytes.
terminate called after throwing an instance of 'std::bad_alloc'
what(): std::bad_alloc
error: exception occurred: Subprocess aborted
critical: In unknown, line 0
critical: Cannot open data file " "" "
Here is your answer, looks like there is too big of an allocation (70Gb).
Is that data big ?
yes it is! but what I dont understand is that even if i do a clip box with a few elements (really small box) it crashes also (when I am having 10gb remaining, and I am consuming 32gb for the original data and i am selecting less than 1% of the volume of it).
I suspect an allocation on the entire domain, definitely a bug to fix here.
if internal to kitware i dont have an issue to share the data (i send it to you in a private link) you want me to report an issue or do something else?
Ill try to repro first.
here if you want you can get the save state (althought there is absolutily nothing fancy on it, only the source filter fo the image reader). i really need to be able to extract the data so i can work on (right now i am stock with this). the data I send you a private message with the .vol file and .vol.info file to be downloaded from a tar file
Indeed, please share a state file, as I dont know how you configured the ImageReader.
here you have the parameters,
I confirm that during the application of clip, I see a spike usage of RAM which is then release immediatly. This definitely looks llike an allocation that should not be done, please open an issue.
So, the issue comes from clip transforming the image (uniform rectilinear grid) ie., vtkImageData to unstructured grid ie., vtkUnstructuredGrid this provokes a spike of memory (3 times the original ram consomed by the source image) where all the original data is converted before doing the cliping, reason why even if the clip is really small, my ram was not enought.
a solution is to use the Crop filter (by default it is not exposed in the paraview interface) by:
Crop(Input=sourceFilterOfImage, OutputWholeExtent=[vXMin, vXMax, vYMin, vYMax, vZMin, vZMax])
with the vXMin, vXMax, vYMin, vYMax, vZMin, vZMax being the voxels where one will cut the image.
this will give back still a image (uniform rectilinear grid) but this time cutted by a box of the sizes mentionned.
I created a little function to still use clip without the ram consomtion, by simply using as middle men the Crop filter and then the clip one.
def clipBoxOnImage(filter=[], typeOfClip='Box', Length = [20.0, 20.0, 20.0], Position = [1.0, 0.0, 0.0], Normal = [2.0, 0.0, 0.0], Origin = [], Invert = 0):
    if filter==[]:
        filter= GetActiveSource()
    if filter.GetDataInformation().GetDataSetTypeAsString()=='vtkImageData':
        #get the voxel size
        oneVoxel=Crop(Input=filter,OutputWholeExtent = [0, 1, 0, 1, 0, 1])
        [xMin,yMin,zMin,xMax,yMax,zMax]=getBoundingBox(filter=oneVoxel , alignOfAxis=False)
        voxelSize=[xMax-xMin,yMax-yMin,zMax-zMin]
        if typeOfClip=='Box':
            if Origin:
                positionInVoxels=[math.ceil(Origin[i]/voxelSize[i]) for i in range(3)]
            else:
                positionInVoxels=[math.ceil(Position[i]/voxelSize[i]) for i in range(3)]
            LengthInVoxelsHalfs=[math.ceil(Length[i]/(2*voxelSize[i]))+2 for i in range(3)]
            inputForClip=Crop(Input=filter, OutputWholeExtent=[positionInVoxels[0]-LengthInVoxelsHalfs[0],    positionInVoxels[0]+LengthInVoxelsHalfs[0],    positionInVoxels[1]-LengthInVoxelsHalfs[1],    positionInVoxels[1]+LengthInVoxelsHalfs[1],positionInVoxels[2]-LengthInVoxelsHalfs[2],positionInVoxels[2]+LengthInVoxelsHalfs[2]])
        if typeOfClip=='Plane':
            if Normal.count(0)!=2:
                print('only supported for axis aligned planes')
                return
            OriginInVoxels=[math.ceil(Origin[i]/voxelSize[i]) for i in range(3)]
            Normal=[abs(i) for i in Normal]
            voxelBounds=filter.GetInformation().bounds
            maxVoxelBounds=[voxelBounds[1],voxelBounds[3],voxelBounds[5]]
            LengthInVoxelsHalfs=[OriginInVoxels[i] if Normal[i]!=0 else maxVoxelBounds[i] for i in range(3)]
            if Invert:
                inputForClip=Crop(Input=filter, OutputWholeExtent=[0, LengthInVoxelsHalfs[0],    0,   LengthInVoxelsHalfs[1], 0, LengthInVoxelsHalfs[2]])
            else:
                inputForClip=Crop(Input=filter, OutputWholeExtent=[LengthInVoxelsHalfs[0],    maxVoxelBounds[0],    LengthInVoxelsHalfs[1],    maxVoxelBounds[1] ,LengthInVoxelsHalfs[2], maxVoxelBounds[2]])
    else:
        inputForClip=filter
        print('this function should be used only in vtkImageData, getting same result as default behavior of simply clipping the data directly')
        if Origin!=[]:
            Position=[Origin[i]-Length[i]/2 for i in range(3)]
        clip1 = Clip(Input=inputForClip,ClipType = 'Box')
        clip1.ClipType.Set(
        Position=Position,
        Length=Length,)
    elif typeOfClip=='Plane':
        clip1 = Clip(Input=inputForClip)
        clip1.ClipType.Set(
        Origin=Origin,
        Normal=Normal,
        Invert=Invert)
    return clip1
    else:
        inputForClip=filter
        print('this function should be used only in vtkImageData')
    clip1.ClipType.Set(
    Position=Position,
    Length=Length,)
    return clip1
also, it worth noticing that the Crop filter is NOT shown by default in paraview, but usable only in python, if one wants to apear in like Ctr+space bar/ crop one needs to download this file and go in paraview tools/manage plugings/load new… and select the xlm file. then there will be a new pluging called ‘filters_imagingcore’ and if one clicks over it, one can set to auto load to have access each time one uses paraview.
https://gitlab.kitware.com/paraview/paraview/-/issues/23151#note_1736978
