Create a Solid surface from points using the Delaunay 3D filter
I have a set of discrete visualization points as seen in the image which is in the shape of the letter H (left side of the image). I’m trying to make a solid surface for better visualization using these points using the Delaunay 3D filter of Paraview. However, when I do this I’m getting a rectangular shape as seen in the right side image. How can I fix this? Thanks for the help.
@Charles_Gueunet
@Renard You may want to play around with the Alpha parameter, which approximately correspond to the maximum edge size you want in the result:
Smaller edges are required to enter into concave area.
Thank you for the response
