Hello Paraview,
I have an EnSight format model that contains multiple parts. The Paraview reader creates a vtkMultiBlockDataSet:
I want to group parts into assemblies, which can be done with the Extract Block filter and then Group Datasets filter. To give:
Can this two step process be simplified by creating a file (xml ?, JSON ?) that instructs to read the EnSight *.case file and then organize the parts into assemblies?
The Information panel for the GroupDatasets shows the structure for such a file, except the part that reads the EnSight file. I tried fudging a *.vtm file, but unsurprisingly the EnSight case file wasn’t recognized (it expected *.vtu, vtp …)
<?xml version="1.0"?>
<Root type="vtkDataAssembly" version="1.0" id="0" vtk_category="hierarchy" label="vtkMultiBlockDataSet" cid="0" vtk_type="13">
<dataset id="0" />
<assembly1 id="1" label="assembly1" cid="1" vtk_type="13">
<dataset id="1" />
<fixedShape id="2" label="fixedShape" cid="2">
<dataset id="2" />
</fixedShape>
<fixedShape1 id="3" label="fixedShape1" cid="3">
<dataset id="3" />
</fixedShape1>
<fixedShape2 id="4" label="fixedShape2" cid="4">
<dataset id="4" />
</fixedShape2>
<fixedShape3 id="5" label="fixedShape3" cid="5">
<dataset id="5" />
</fixedShape3>
</assembly1>
<assembly2 id="6" label="assembly2" cid="6" vtk_type="13">
<dataset id="6" />
<prismatic1 id="7" label="prismatic1" cid="7">
<dataset id="7" />
</prismatic1>
<prismatic id="8" label="prismatic" cid="8">
<dataset id="8" />
</prismatic>
<spring id="9" label="spring" cid="9">
<dataset id="9" />
</spring>
<spring1 id="10" label="spring1" cid="10">
<dataset id="10" />
</spring1>
</assembly2>
</Root>
Thanks, Bob
