Hello everyone,
sorry to disturb you i am new in paraview, my problem is i want to make a 3D model from seperate 2D vtk model and then calculate volum isosurface in 3D model for resource estimation. I already search in google but i didn’t found the answer, Thankyou
can you share your files ?
f009_res.vtk (869.3 KB) f0010_res.vtk (578.1 KB) f0013_res.vtk (974.2 KB) f0014_res.vtk (637.7 KB) f0017_res.vtk (974.6 KB) f0018_res.vtk (915.0 KB)
the line layout is
10&9
100m
14&13
100m
18&17
do you know the solution sir?
Doesn’t seem an easy task. I would suggest changing how you generate the data.
If you can’t you will need to use Transform, RessampleWithImageFilter and AppendDataSet.
