Hello all,
I am currently attempting to build my own ParaView plugin by following ParaView/Plugin HowTo.
Some info of my OS and Plugin :
OS: MacOS Ventura 13
Chip: Apple M1
Paraview version: 5.11.01
Plugin file tree
- I built ParaView from source. The first problem I met is, when I ran command
cmake ..in the directorybuildI received the following message:
CMake Error at CMakeLists.txt:6 (find_package):
By not providing "FindParaView.cmake" in CMAKE_MODULE_PATH this project has
asked CMake to find a package configuration file provided by "ParaView",
but CMake did not find one.
Could not find a package configuration file provided by "ParaView" with any
of the following names:
ParaViewConfig.cmake
paraview-config.cmake
Add the installation prefix of "ParaView" to CMAKE_PREFIX_PATH or set
"ParaView_DIR" to a directory containing one of the above files. If
"ParaView" provides a separate development package or SDK, be sure it has
been installed.
-- Configuring incomplete, errors occurred!
As far as I know , this problem happens when CMake cannot find the ParaView package configuration file. However, I did built Paraview and set ParavView_DIR (I also installed ParaView with brew install command in Mac). It still failed.
Does anyone have idea how I could solve this problem?
