I have followed the PyGSLIB tutorial (Tutorial: Resource estimation with PyGSLIB — PyGSLIB 0.0.0.3.9 documentation) and am now ready to try running the code on my own data. I have successfully imported the drillhole tables, created the drillhole objects… all the way to tagging my samples with the domain code.
I encounter a problem when I get to the code lines:
>># creating a partial model by filtering out blocks with zero proportion inside the solid
>>mymodel.set_blocks(mymodel.bmtable[mymodel.bmtable['D1']> 0])
>># export partial model to a vtk unstructured grid (*.vtu)
>>mymodel.blocks2vtkUnstructuredGrid(path='model.vtu')
where the kernel dies, specifically when trying to export the model to a VTU file format. To explore some more I tried declustering the parameters, but when I entered the code:
>>wtopt,vrop,wtmin,wtmax,error, \
xinc,yinc,zinc,rxcs,rycs,rzcs,rvrcr = pygslib.gslib.declus(parameters_declus)
The kernel did not complete the task, and I was not able to plot the deculstered optimization results.
--------------------------------------------------------------------------- NameError Traceback (most recent call last) Input In [27], in 1 #Plotting declustering optimization results ----> 2 plt.plot (rxcs, rvrcr, ‘-o’) 3 plt.xlabel(‘X cell size’) 4 plt.ylabel(‘declustered mean’)
NameError: name ‘rxcs’ is not defined
ERROR! Session/line number was not unique in database. History logging moved to new session 118
As far as I can tell, this is because I have not set up an appropriate wireframe - the STL file I have does not seem to have the geospatial data listed in terms of meters (which I think the data from the tutorial is)… but I can’t seem to find a way to convert the data from my STL file to a useable format.
My question is: Can I use ParaView to convert an STL file of a 3D portion of the earth’s surface downloaded from 3D-mapper.com, into a useable wireframe to continue with the PyGSLIB code?
If anyone could shed some light on this issue, I would really appreciate it.
